#1 Posted : Sunday, 14 December 2008 12:11:50 PM(UTC)
hi all,
just need some info about a better ignition system for my hq 1 tonner. it currently has a 308 that been stroked out to a 380. my problem is it takes a while for it to kick over and i want it to start every time as soon as i turn the key. is there anything i can do to get it to this condition??? the motor is fairly new and it does have a fairly new battery.any ideas?
cheers guys
#2 Posted : Monday, 15 December 2008 4:48:53 AM(UTC)
if its that worked to be stroked that far. what ignition are you running with at the mo.
#3 Posted : Monday, 15 December 2008 7:58:40 AM(UTC)
not to sure what ignition its running at the moment. looks pretty standard. any ideas on a good ignition system to run through it?
pont69 Offline
#4 Posted : Monday, 15 December 2008 7:31:38 PM(UTC)
pont69
MSD or something of the likes. a high amp electronic dizzy and coil
Get your feral little mittens off it!
Cheers, James
Dr Terry Online
#5 Posted : Monday, 15 December 2008 8:11:07 PM(UTC)
The Bosch HEI system off a Blue/Black V8 is the best all round for street use.
Dr Terry.
Tex Scrotum rides again Offline
#6 Posted : Monday, 15 December 2008 11:37:48 PM(UTC)
Do Holdens run a ballast resistor set-up on the ignition system?
If they do then maybe your ignition is only getting 6volts on start-up.....make sure the wire that feeds a full 12volts to your coil whilst the startermotor is turning over is hooked up
