HQforme Offline
#1 Posted : Monday, 13 April 2009 9:19:29 PM(UTC)
HQforme
My 202 is richer than Bill Gates after a lotto win!
And it proves that the highly reputable race shop that did my tune simply ignored my request to check the ratios.
Its a reasonably worked 202, X2 setup, but with two single stromberg carbs (1 5/32) rather than the smaller factory twin setup. I've known it's rich for a while, mentioned it other topics. Had it on an analyser, and after fixing the idle, i ran it at revs on the main jets, and it read 10.2/1!!!!!
I'm looking at altering main jets, power jets and maybe even machining up a little restrictor tube for the venturis, which i'm told was fairly common "back in the day".
I haven't yet pulled the main jets to check size, but i thought i'd see what people have to say so i can muse as i work.
Cheers.
"Silly modern cars"
petaus Offline
#2 Posted : Tuesday, 14 April 2009 5:45:50 AM(UTC)
petaus
did you give them a bill for stuffing your first engine?
this is why a holley would be so much easyer to tune, available gets and power valves, adjustable accelrator pump and squirters etc.
not saying it cant be done with the strombergs, you need to sta
HQforme Offline
#3 Posted : Tuesday, 14 April 2009 8:18:07 AM(UTC)
HQforme
I should have! I had to rebuild it, the bores were glazed. But its so hard to prove anything this far down the line, and you know what its like, "he said she said" crap, receipt just says "dyno tune, $"
Now ive got to sort it before it ruins things aga
Edited by user Tuesday, 14 April 2009 8:18:47 AM(UTC)  | Reason: Not specified
"Silly modern cars"
