HK350_2233 Offline
#1 Posted : Tuesday, 28 July 2009 4:41:58 AM(UTC)
HK350_2233
Hi all, need abit of help with timing. Now i know if you advance the timing to much you will get pinging. But if you retard to much can you still get pinging? Dose the pinging sound like a loose roller rocker under load ? This is on a SBC to.
Thanks.
kin Offline
#2 Posted : Tuesday, 28 July 2009 4:55:10 AM(UTC)
kin
hmmmm while I am not looking at your car and no mechanic ...
Yes pinging can happen if the timing is to advance or the other way.
does the ping happen @ idle ? ... dont think this can happen. Has to be under load
HK350_2233 Offline
#3 Posted : Tuesday, 28 July 2009 5:01:21 AM(UTC)
HK350_2233
Underload
