#1 Posted : Monday, 21 February 2005 7:08:40 AM(UTC)
Gidday, I have an old 308 in a ski boat that is getting water in the oil,any suggestions to the cause, valley cover/head gasket? Also how do you tell the difference between turbo pattern block or trimatic
#2 Posted : Wednesday, 2 March 2005 4:44:28 AM(UTC)
the most noticable change in bolt patterns is that the two top bolt holes sit higher to the top of the block on a trimatic pattern rather than a turbo. as for the water check your head gaskets, valley cover & timing cover. ive seen the timing chain slacke
