308hjute Offline
#1 Posted : Thursday, 8 October 2009 7:43:27 AM(UTC)
308hjute
Guys,
How much surgery is required to the front of the chassis rails to put a WB ute front onto my HZ tonner?
And is it possible to modify the radiator mounts so I can use the HZ radiator and shroud? It is only 12 months or so old so not really keen on buying another one.
Kev
HQforme Offline
#2 Posted : Thursday, 8 October 2009 10:28:58 AM(UTC)
HQforme
"Silly modern cars"
vintageholden Offline
#3 Posted : Thursday, 8 October 2009 12:24:49 PM(UTC)
vintageholden
not much i dont think
i have a wb ute and fitted hz premier front
the reverse of what your doing
bonnet the same guards different and stone tray.
#4 Posted : Thursday, 8 October 2009 4:17:50 PM(UTC)
Was thanked: 616 time(s) in 583 post(s)
You have to cut the nose off the rails and hence lose the front bar bolts, so when the WB bar goes on only 2 x bolts go in. I have seen them notched at the nose, rather than cut off altogether so the bar bolt remains, but its of no use to you anyway with a WB nose/bar.
Youll also have to either put up with the HZ tonner cowl panel not lining up with the WB bonnet, replace the cowl with a HJ-WB (except non-BO6 HJ-HZ tonner, which is what yours is) cowl or bog it to match.
You can use the HZ radiator and shroud but WB cross-flow radiator is far superior for cooling so id keep it if you can.
bronsonHX Offline
#5 Posted : Friday, 9 October 2009 3:53:07 AM(UTC)
bronsonHX
leave it as is, the HZ front looks better i think..
308hjute Offline
#6 Posted : Friday, 9 October 2009 4:37:49 AM(UTC)
308hjute
Byron,
The mismatch of the cowl and bonnet doesnt worry me at the moment as the yellow cab is not staying on there much longer. The better cab I bought not long back has the correct cowl. The front I am picking up doesnt have a radiator while my HZ one is only a couple of years old.
How far back do you cut the nose off the rails?
Bronson,
It currently doesnt have a front clip on it. Sold the commercial front months ago.
Cheers guys
Kev
#7 Posted : Friday, 9 October 2009 4:13:12 PM(UTC)
I dont know the exact measurements as ive never measured it but it is around 40-50mm. Look at the donor car that the front is coming of and youll see. Measure from the rear two front bar bolts on each side on the WB rails, and cut the HZ ones in the same spot.
adam PERTH Offline
#8 Posted : Wednesday, 14 October 2009 3:12:11 PM(UTC)
adam PERTH
about 1 inch forward of the rad support bolts that go thru the chassis
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
