Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Was the trimatic available in the HT.cheers John.
Thanks: 1 times Was thanked: 626 time(s) in 590 post(s)
Yes, behind 253 and 308 but not until pretty late HT. The only HTs that didnt get a trimatic were GTS350 and Brougham - both stayed with the Powerglide.
What about the sixes, the August 72 parts catalogue lists converter housings for them also. Cheers John.
6cyl trimatic replaced the 6cyl powerglide at the same time it did for Holden V8s in HT.
thanks for the great info
Do you have a Powerglide Bellhousing with Trimatic bolt pattern for sale???
WTF ?? Please explain. Dr Terry |
There is PG to HOLDEN V8 housings. And PG to 6CYL they are different housings. The Chev PG come as one pice i think. I think he is looking for a PG housing to fit holden V8 using the 2 speed PG.
You are a member of these groups:: Registered, Veteran
V8 aussie pattern Glide is i think what he wants... Goodluck with that one... |
Hi,
I have a Powerglide to suit Holden V8 for sale in WA, south of Perth.
It came from a HT Brougham.
Phil90120 (or anyone else) - let me know here if you are interested.
Mike
there was or is a bellhousing powerglide to 253/308 on flee bay.
