greenhj Offline
#1 Posted : Tuesday, 2 March 2010 2:24:32 AM(UTC)
greenhj
Was thanked: 15 time(s) in 13 post(s)
Afternoon, can someone tell if a HZ rear disc conversion on a currently drum braked kingswood will push the track out or will it stay the same?
If it does increase the track, by how much (roughly)
11.38@117
#2 Posted : Tuesday, 2 March 2010 2:44:27 AM(UTC)
No, the track dimension will remain the same. The disc brake axles are shorter to make up for the difference in thickness between the disc & the drum mount face.
The best argument against democracy is a 5 minute conversation with the average voter.
greenhj Offline
#3 Posted : Tuesday, 2 March 2010 4:46:42 AM(UTC)
greenhj
thanks Doc, so if i fit the aforementioned discs to my existing 9" with drums, it should push the tyres out away from the inner guards (ive got a slight rub that i dont want to use a hammer to fix lol)
thanks!
11.38@117
#4 Posted : Tuesday, 2 March 2010 4:53:01 AM(UTC)
thanks!
11.38@117
Yes, you will achieve your desired track increase, but what about caliper mounts ? They must match the disc rotors position precisely.
Dr Terry.
greenhj Offline
#5 Posted : Tuesday, 2 March 2010 6:53:01 AM(UTC)
greenhj
without seeing the backing plate (hidden in vast piles of assorted junk) i suppose the difference between the drum thickness and disc thickness machined into a spacer for the caliper might do it.
I might end up with a shonky* wheel spacer if it all gets too hard, and for the price of discs, booster, caliper rebuild i could probably just fix the diff.
*shonky "off the shelf" spacer with added machined wheel centre bore to axle spigot adapter and long shank wheel nuts, studs are 4" by 1/2" anyway.
11.38@117
