what full length bumper fits hq ute?ive tried a sedan and wagon(hx)too wide by 40mm whats left? hq i suppose? anyone know or fitted one? Jim in Adelaide...Hindsight is bad vision! Edited by user Thursday, 11 March 2010 6:17:50 AM(UTC)
| Reason: Not specified |
Jim in Adelaide.. |
gday jim, this was discussed on oldholden a while ago
you need a HQ wagon bumper, iirc you have to cut the bumper and add a bit to make it longer, have a search over there its been discussed a few times, ive never really taken much notice as ive no intensions of ever doing it
I always figured they were wagon bumpers. Ive got one that I pulled off a panelvan a couple years ago but no idea what it originally came from.
thanxz guys, ill go check that out p.s. its for a friend ,i personally dont like the look,for me its bumperettes all the way....thanxz *********************************** followed up on that:its says their interchangable but they arent. ************************************ Jim in Adelaide...Hindsight is bad vision! Edited by user Thursday, 11 March 2010 6:25:02 AM(UTC)
Jim in Adelaide.. |
whoever told you that isnt holding something correctly....they all fit,but to make them fit and look like they should be there and tucked in nicely at the corners they need to be shortened.. going to church makes you no more a christian than standing in a garage makes you a car... www.classicozwreck.com.au |
I had one on my van from a sedan, I cheated though on install and drilled a hole each side and mounted them on the tailgate stopper brackets looked okay with the black rubber strip on it.
cloudy...thats the most common way to mount them...its a hell of a lot of work to modify brackets to make them fit so the ends dont vibrate.. jim,part numbers are different because of the different styles of bars between the models but they will all fit...right thru to wb statesman.. going to church makes you no more a christian than standing in a garage makes you a car... www.classicozwreck.com.au |
I must have used a sedan one ,so its the wagon?...1700 mm? so they need to be shortened?
Jim in Adelaide...Hindsight is bad vision! |
Jim in Adelaide.. |
A sedan one? how many tail lights etc do ya want??
< Gotta Luv It! |
 <b><font color="orange">< 4 SALE , SELLING .......SOLD!</b></font id="orange"> |
hx, no lights? (re:first post).ps i dont like them,its not for me, i like bumpurettes. Jim in Adelaide...Hindsight is bad vision! Edited by user Friday, 12 March 2010 3:00:18 AM(UTC)
Jim in Adelaide.. |
no...they are all the same width and will all fit....just for my own brain i went out the back here and measured a wagon bar and a sedan bar both rubber stripped hx...same as... going to church makes you no more a christian than standing in a garage makes you a car... www.classicozwreck.com.au |
They look ridiculous too in my opinion. I was looking at a really good HZ Sandman recently with a HQ wagon rear bar. Removing the bar would be my first job, and putting the bumperettes back on.
greg ,do they need shortened as per your previous post?
Jim in Adelaide.. |
im with byron as far as looks go....if you wanted the bar to sit neatly on a ute or van then yes they need to be narrowed..this wb van has a narrowed wb statesman bar on it...we had it modified by vinneys in melbourne..    going to church makes you no more a christian than standing in a garage makes you a car... www.classicozwreck.com.au |
Yeah,I repeat ,I dont like them ,but a mates hell bent on putting one on his ute,which wont look too bad(ute)..but I only like BUMPURETTES. thanxz everyone,now its his problem.
Jim in Adelaide.. |
they look okay with the right bumper style, I dont mind either look but not with HQ sedan bumper I have seen these on vans and its fingers in throat stuff.
cloudy ,doin research for kevin that used to work at hirotec,you know him?
Jim in Adelaide.. |
