lukee148 Offline
#1 Posted : Friday, 2 April 2010 5:50:16 AM(UTC)
lukee148
i have a 1999 vt commodore, i recently put a second hand engine in it, since then i have had a few trouble codes showing up every now and again such as abs, trac cntrl, and check engine, these usually go away if i turn the car off and bak on, but tonight i went to drive my car and my check eng light is not turning off, and then will after a little bit, but makes my car run like s***, any ideas?
#2 Posted : Friday, 2 April 2010 7:10:16 AM(UTC)
Have you left a wire off a sensor somewhere when you replaced the engine?
Vandals and graffiti "artists" do everyone a favour and target parking meters and fixed speed cameras only.
lukee148 Offline
#3 Posted : Friday, 2 April 2010 7:37:26 AM(UTC)
lukee148
nah mate because it runs okay usually,
#4 Posted : Friday, 2 April 2010 8:36:30 AM(UTC)
get a mechanic to reset the codes again
lukee148 Offline
#5 Posted : Friday, 2 April 2010 8:50:10 AM(UTC)
lukee148
im in my first yr, i just havent mentioned it too my boss yet, but yea i will take it too the work shop tomoz and plug the scan tool in
Casper Offline
#6 Posted : Saturday, 3 April 2010 6:29:38 PM(UTC)
Casper
Check that the nut on the back of the alternator is tight. The one that holds the main wire to the battery.
Check your charging rate.
