ht307munro Offline
#1 Posted : Sunday, 6 June 2010 2:14:38 AM(UTC)
ht307munro
Hi all. I need to remove a rusty parcel shelf from my monaro. (Have a good one from a HG sedan). Do you need to brace between the rear pillars (or anywhere else for that matter) when you cut the old one out. I don't want anything to move and not line up when the new one is put in. Is there any "trick" or tips (other than new parcel shelf in exact same spot as original) to ensure the new boot hinges are in the exact same spot as the originals?
Alex
Alex
#2 Posted : Sunday, 6 June 2010 3:54:08 AM(UTC)
They are actually not the same . The rear upper shelf panel are different , and the inner part where the circles are are different on the ends . A Kinga one is really only good for fixing parts of it or where big speakers holes have been . Waddingtons make a whole new one for $650 or there abouts i believe . Much better to go that way .
www.monaromuscleparts.com
#3 Posted : Sunday, 6 June 2010 4:09:17 AM(UTC)
what???? you not making them james?? omg...waddington makes them for $650, you should tool up and then sell them for $6500 each,and then call yourself MMParcelshelfs.com, they we would all have to get a bank loan to even afford 15mins of your valuable time hahahah
petaus Offline
#4 Posted: : Sunday, 6 June 2010 4:11:40 AM(UTC)
petaus
ah wreck im bringing mine down to you for the sag hump, i hear your great with the sledge hammer???
pete.
#5 Posted : Sunday, 6 June 2010 4:15:46 AM(UTC)
pete.
i'm even more of a wizz when it comes to using a gas axe hahahaaa
ht307munro Offline
#6 Posted : Sunday, 6 June 2010 7:15:49 AM(UTC)
ht307munro
Are you saying the sedan one won't fit? Either way when you remove the old one do you need to brace anything? Thanks.
Alex
Alex
This page was generated in 0.181 seconds.
