chris woodrow Offline
#1 Posted : Saturday, 2 October 2010 8:18:15 AM(UTC)
chris woodrow
NGK BP5FS spark plugs that fit the standard Holden 202 red motor head do not fit the yella terra head. Can anyone tell me the plugs that do fit a yella terra iron head?
#2 Posted : Sunday, 3 October 2010 5:05:03 AM(UTC)
Most Yella Terra heads are just Holden heads that have been reworked, so standard spark plugs will fit, but there are several different heads.
EH-HG heads use BP5ES
HQ-HZ heads use BP5FS
WB/VC to VK heads use BP6EFS-13
#3 Posted : Sunday, 3 October 2010 7:19:36 AM(UTC)
chris woodrow
Many thanks for that. Now I can get on with the real job of fixing all the tin worm in the body of the car.
