jayHK69 Offline
#1 Posted : Tuesday, 28 December 2010 2:50:23 AM(UTC)
jayHK69
have come to the conclusion that i can`t afford gts guards for my hk,
so i`m going to weld a set of flutes into my current guards.
can someone give me the exact measurements for the location of the flutes in the guards please ?
thanks in advance
jayson
Oily Offline
#2 Posted : Tuesday, 28 December 2010 7:22:45 PM(UTC)
Oily
Jayson
Careful when you do the mod as I have seen a HT recently that had me scratching my head until I realised they were welded in back the front.
I have often wondered if the flute and lower patch panel could be made in one as there are plenty of guards that could do with both. oily
papaya hx Offline
#3 Posted : Wednesday, 29 December 2010 6:22:34 PM(UTC)
papaya hx
why not have your guards pressed with the flutes at coonabarrabran. These blokes do a great job 02 6842 2550 cheers Ron
jayHK69 Offline
#4 Posted : Friday, 31 December 2010 11:22:24 PM(UTC)
jayHK69
unfortunately have no way of getting to coona & back & can`t afford to freight them
AMunro327 Offline
#5 Posted : Saturday, 1 January 2011 3:32:59 AM(UTC)
AMunro327
Does this help Jason?
Dimension A is 140mm, measured from the edge of the guard to the leading edge of the first cut out.
Dimension B is 245mm, measured from the bottom of the guard to the bottom of the cut outs.
Cheers, Bob
jayHK69 Offline
#6 Posted : Sunday, 2 January 2011 12:17:15 AM(UTC)
jayHK69
many thanks bob,that`s exactly what i was after
jayson
