hey lads,i have a few steering boxs in the shed and was wondering if there are any diffrences in hk ht hg boxes apart from the 16.7 gts.all other steering box numbers only tell you the build date etc yea?.all other ratios the same yea?
Yea & yea.
Except that the 16.7:1 box was fitted to not only all HK/T/G GTS, as well as ALL HK/T/G with power steering.
When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
