How much difficulty in replacing the starter in a VS auto 6 cylinder? Any tricks? thanks
its not difficult to change 2 bolts from underneath and the wiring (dont forget to disconnect battery first)
pete
OLD HOLDENS NEVER DIE |
There is also a brace between the motor and the box that has to be removed. Quite easy, all can be done from the passenger side, with the car lifted onto stands.
Warren
The best part about being wrong is the pleasure it brings to others.
if you have a set of pacemaker extractors, it means extractors out, air box out, spark plugs on that bank out too.
Tuning for Holley carbs in Perth? PM me. |
