Hi ever1,i got this rear hx statesman with a turbo 400 which is not uncommon but this vehicle was fitted ABS braking so to speak. It has this module on the side of the gearbox and the speedo cable bolts on and it has 2 wires coming out of it controlling this braking system it also can be used for cruise control i have been told it comes from the Buick family,they use this system for cruise and this extra brake booster system.this module has started to leak auto trans fluid and i have tried to find a replacement,i have talked to some auto pros and all have said good luck finding one and it has come to this stage were i cant find one, i have even called USA and they cant help,can anyone help or am i stuck in a rut. i can upload some pics if needed.
Joined: 29/07/2006(UTC) Posts: 766 Location: in the shed
Thanks: 8 times Was thanked: 14 time(s) in 13 post(s)
Its the Delco-Moraine anti-lock rear drum brake system and I think theres some info in the HJ supplement manual M37545
Not many of those made. Dr. Terry knows a bit about them . . . according to a post from last year.
Thanks: 1 times Was thanked: 606 time(s) in 573 post(s)
I've never seen one, only pictures in the parts catalogues. |
Mate thanks very much for your info this def help, i suppose i might not find one,maybe Dr Terry can point me in the right direction,cheers all the same
