bogart69 Offline
#1 Posted : Wednesday, 23 March 2011 11:06:24 AM(UTC)
bogart69
Hi just wondering is the power steering setup for a Brougham 308 be the same as one for a HG 350 Monaro, I understand that the pulleys may be different but was more thinking the steering arms ram etc would they be all the same size and length. Would there wheel base/width be the same.
Thanks in advance for any help.
If you see rubbish put a circle around it.(FORD)
#2 Posted : Wednesday, 23 March 2011 4:34:25 PM(UTC)
Holden engine setups are the same (obviously differ at engine between 6 and V8). The Chev units have a different bracket that attaches the ram to the rails. That bracket is the impossible bit to find. Most people don't bother anymore, and fit a power rack.
Sebring Orange Offline
#3 Posted : Wednesday, 23 March 2011 5:50:17 PM(UTC)
Sebring Orange
Call Roger on 9758 1965 , he will be able to help you with genuine power steer on your HK HT HG
The HKTG Garage Offline
#4 Posted : Wednesday, 23 March 2011 6:23:26 PM(UTC)
The HKTG Garage
Not only is the bracket for the ram to subframe different but also te drag link for Chev engined models. Best to get a set up from an HK Brougham.
bogart69 Offline
#5 Posted : Friday, 29 April 2011 12:23:11 PM(UTC)
bogart69
Thanks for the help fellas will give Roger a bell.
