#1 Posted : Sunday, 3 April 2005 6:27:18 AM(UTC)
gday. i just brought a HZ ute with a warm 202 and Celica 5spd. GTS wheels, guads and steering whell. prem front. recaro seats. all for $500!!!! anyway the problem is the Celica box pops out of 4th gear any idea's as to how this can be fixed??
666 Offline
#2 Posted : Sunday, 3 April 2005 6:42:18 AM(UTC)
666
This is common when the front bearing is gone. 4th gear locks the shafts 1:1.
666
666
#3 Posted : Sunday, 3 April 2005 6:43:02 AM(UTC)
It will be WAY cheaper to simply buy another box and swap it over. Quite often, a box jumping out of gear is caused by bent selectors inside the box or very worn internals. Either way, save yourself a heap of work and expense and start looking for another
666 Offline
#4 Posted : Sunday, 3 April 2005 6:46:14 AM(UTC)
666
Also just realised that u've probably got an adaptor housing between the engine and box that maybe misaligning the input shaft (ie simulating the front bearing problem)You may have a dodgy one,Goodluck.
666
666
#5 Posted : Sunday, 3 April 2005 7:02:17 AM(UTC)
it changes gears real nice except downchanging from 4th to 3rd it clunks slighhtly. but if you hold it in forth it goes great
666 Offline
#6 Posted : Sunday, 3 April 2005 7:47:23 PM(UTC)
666
Don't worry about ur selectors being bent.If it's jumping out of - 4th only - its a problenm at the front. U see - When power comes into ur box, the INPUT SHAFT has a gear that IS SUPPORTED by the FRONT BEARING. From here the power goes down into a cluste
666
#7 Posted : Friday, 8 April 2005 7:34:48 AM(UTC)
invested in a parts car that had a warm 202 and a supra five speed in it. The fella i got it of said that he went through 3 celica boxes in a couple of years before he put the supra box in it. The supra box was still going strong 3 years later. You can ge
#8 Posted : Friday, 8 April 2005 10:29:24 PM(UTC)
I'll sell you a complete Supra 5-speed that is out of a HJ 6cyl if you wish to go that way. It was in a HJ sedan. Complete with free running 202 (not for a few years now) with Holley etc. Everything from fan to tailshaft, including sedan gearbox crossmemb
#9 Posted : Monday, 11 April 2005 12:33:15 AM(UTC)
gday. i just pulled the mototre asnd box out of the ute. motor has been sold so i took the box off. and now with no clutch on it the shifter stays in 4th. so is it possible that it was just a bit misaligned??
666 Offline
#10 Posted : Monday, 11 April 2005 5:48:56 PM(UTC)
666
Without the engine to apply any decent amount of torque it,s impossible to say. If ur thinking of selling the box as is, someone may get ripped off ?
666
666
Guest (11)
