Fastlane
Holden Forums
Holden General Discussion
Trying to identify what my car is exactly
On my compliance plate it says that i have a HQ Coupe Utility 3/73. I have tried to check the VIN but it is unable to be identified or decoded. Can someone please help.
post the vin here and someone will be able to help
what have you been using to try and decode it?
I have used the VIN and but it is only 6 numbers not 17 and there is a Q in the Vin which the sites will not except. I have tried using the chassis and model numbers as well. But is it heard of a HQ Coupe Utility whic is on the plate. The car has a prem front end, Gts guards V8, trimatic, unsure of paint work, 2 seater. I keep thinking it might be a sandman ute.
Does it have any plates, if so, what do they read ?
From what you've given us it won't be a Sandman, because of the early build date. Sandman production began in 1974.
The GTS guards & Premier front won't be factory, but the V8 & Tri-Matic may be, depending on what the numbers say.
Dr Terry |
Not quite true DR T. There was at least one HQ ute that left GMH with a Premier front and GTS guards, but it was 3/72 build and its running gear was more special than V8 M40! There was another almost identical mechanical build in 5/72 but I do not know if it was the same cosmetically.
Krissy, you are reading the CHASSIS number, not the VIN. The VIN is on the skinnier of the 3 x ID plates. For a 3/73 V8 HQ ute it will look something like 8N80RCJ3688987Q. The digits that will change will be the N (M or N), the R (D, E, R, S or T), J36 (could be J36, H26, L23 or H76 or close to these) plus the rest of the following digits other than the Q could be anything. |
Yes, fair enough, but that was special build. Fred Average could not go to a dealer & order GTS guards & a Premier front as a factory option. Having said that, many dealers offered that service: i.e. supply, fit & paint those panels to a Belmont, Kingswood or whatever, but that doesn't make it a factory option. Dr Terry. |
Fastlane
Holden Forums
