Jonesy77 Offline
#1 Posted : Friday, 19 August 2011 7:34:06 PM(UTC)
Jonesy77
Hi all I've just been informed buy the wife that we now have a HR wagon Shell only,mmmm and need a front end to go under it,i've heard that their is a few ways you can go about it which is the neatest way and can you use some hq-wd bits,
any info would be great.
cheers steve
Happiness is not a destination but a way of life (so drive a kingswood)
peter_flane Offline
#2 Posted : Saturday, 20 August 2011 4:00:38 AM(UTC)
peter_flane
You can get a complete HR front end.
Then fit HQ stub axles and later HZ alloy Girloc callipers and HQ disc brakes. You will need to fit 14" wheels at least. Keep your HR steering arms and drag link.
This is a cheap upgrade that bolts on. It will lower the car by 20mm also.
This is assuming you are going to be running a 6 cyl engine.
Jonesy77 Offline
#3 Posted : Saturday, 20 August 2011 5:07:52 AM(UTC)
Jonesy77
Thanks mate that helps heaps and gives me lots of ideas to work with and i already have some of the bits.
cheers steve
