I havent seen these before, http://www.ebay.com.au/i...ies&hash=item19ca8c4738, in terms of Nasco stamped exhaust. Dr Terry can you please confirm whether they did come out in HD - HQ and early Torana's?
I doubt they were ever factory fitted, but in the mid-60s Holden spare parts offered 'sports exhaust kits' which incorporated larger diameter pipes & sports mufflers. I believe these units had Nasco embossed in their case.
Dr Terry |
Unless you climb under your car with your mates and say check this out why would you bother?
This guy has made something for restoration but its not correct for what he thinks it is . Nasco was only stamped/debossed in to the very first "spare part "type Exhaust Mufflers you bought at a Holden Dealer (until the mid 70s or thereabouts when they shut down ). Originally from new on the product line they had the genuine part number debossed and a date code . So its not correct for the production line spec , its spare part correct only. Later issue Mufflers had GM debossed into them rather than Nasco . Pitty as he has done a great job ! Edited by user Friday, 11 November 2011 7:35:35 PM(UTC)
| Reason: Not specified
