Fastlane
Holden Forums
Holden Technical Talk
Long cranking time before firing on VN
Hi guys,
I have a mate with a VN V6 and he needs to crank it for between 5 and 10 seconds before it will fire.
I remember reading somewhere that there is an issue with something to do with the fuel pump.
But for the life of me I can not remember what it was or find where I read it.
Any ideas on what the issue is??
I had the same problem, was a fuel pressure problem, mine was a loose fuel line. Check both fuel lines pressure and return.
Warren
it may have a crook oil pressure switch or low oil pressure. vn would not turn on the fuel pump without oil pressure.
Fastlane
Holden Forums
