roadster Offline
#1 Posted : Thursday, 29 December 2011 6:47:48 AM(UTC)
roadster
Hi Guys
My 307 is running a bit rich at the momment. Its pretty much stock. What would the original jet size be or if anyone has got a recomendatation that would be great.
#2 Posted : Thursday, 29 December 2011 6:14:07 PM(UTC)
The jet size only really controls the air/fuel mixture at wide open throttle. If your engine is running rich you have a problem.
The most likely cause is float level (too high). Get a pro to check out the carby.
Dr Terry.
roadster Offline
#3 Posted : Friday, 30 December 2011 5:50:47 AM(UTC)
roadster
thanks for the tip, sure it could do with a look at.
