Hi , I have a 253 engine and am looking at what era car it came out of . Number is QR719384. Thanks
Somewhere between January and April 1976. Making it HJ. |
Thanks: 1 times Was thanked: 626 time(s) in 590 post(s)
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Why guess, check the casting date on the block and you will know for sure...
That'll tell you when it was cast, not when it was used in a car. Normally you are right and they are close, but sometimes out by months. |
I was after a rough date as its in the hq coupe I bought in 1995 , it was factory 308 4 speed. So i knew the 253 was not there from factory. Thanks for all your info.
Agreed, As the original post was only trying to get an "era" for the motor I'm sure a month or two won't be an issue.
