Glenn72 Offline
#1 Posted : Friday, 2 March 2012 10:00:49 PM(UTC)
Glenn72
does anyone know of anywhere i could get a coolant level sensor/switch that goes in the side of coolant bottle ea 3.9 multi point.Preferably not through ford they charge an arm and a leg they want 250 for bottle without sensor. Any help would be great. cheers
302Superbird Offline
#2 Posted : Saturday, 3 March 2012 8:29:23 PM(UTC)
302Superbird
Don't forget to buy the new mounting rubber grommet too as they are usually stuffed too!
#3 Posted : Sunday, 4 March 2012 3:03:01 AM(UTC)
Have you tried your local cooling system specialist or radiator repairer?
There is not much to go wrong with them as they are only a float with a switch attached. The pivot/hinge for the float may have seized up so a good clean may fix it.
Glenn72 Offline
#4 Posted : Tuesday, 6 March 2012 10:05:21 AM(UTC)
Glenn72
thanks for all your help problem fixed it was a faulty cluster
