Hello guys. Would a brake booster & master cylinder from a WB Stato fit in my HZ 1tonner?Thanks,Mick. |
Water makes it's own sauce |
It will bolt in, but unless the tonner has rear discs it won't work properly. You need a WB commercial cylinder. Also need the WB brake lines. |
