Jonesy77 Offline
#1 Posted : Wednesday, 10 October 2012 2:19:47 AM(UTC)
Jonesy77
G'day all just tinkering in the shed with the 1tonner and found a set of brakes and think they may be 1tonner set as they are not the same as the other kingswoods that i have,the numbers that are on them are as follows-K246 005C HTD (stamped)cast number-L62 also the outer brake pad is twice the size as the one on the piston side any help would be great.
cheers all
Happiness is not a destination but a way of life (so drive a kingswood)
#2 Posted : Wednesday, 10 October 2012 5:12:45 AM(UTC)
Tonners (as in HQ-WB) never had special brakes. They had heat treated front stub/uprights and heavier duty rear axles plus bigger unis but not the brakes themselves. There are different types of brakes along the way though and they may just be that?
Jonesy77 Offline
#3 Posted : Wednesday, 10 October 2012 5:28:21 AM(UTC)
Jonesy77
Sweet as they will fit my tonner but the outer front pad is twice the size as the standard set and thought that they may be special
