Hi I'm looking at a ht monaro and the tags are missing. He has another set that didnt come off the car. There are only 2 tags a big and a little. Both the tags have the prefix 80437 which makes it a v8 from my research, is there anothe plate missing like the compliance or is there only 2 plates for these, thanks
Prior to 1970 HT's only had 2 x plates: Body and VIN. 0437 is a V8 Monaro. If you get the tag numbers and the chassis number off the shell I can get it all sussed out for you. |
