Mr Sir Offline
#1 Posted : Friday, 24 May 2013 6:43:03 AM(UTC)
Mr Sir
Over the years I have collected a couple of Holden V8 gasket kits but am unsure as to what they might be. Looking at what is in the kit what would be a dead give away to know which is a blue, red or a EFI 5.0 kit? I need to start marking things before I store them in the shed. Cheers MS
#2 Posted : Friday, 24 May 2013 9:01:34 AM(UTC)
EFI 5.0 kit will have very different intake & exhaust gaskets (due to sequential ports) as well as unique rocker cover gaskets & rubber seals to go under the 2 rocker cover bolts on each side that go through the covers. The last couple of kits I've used also included the throttle body gasket - making it a dead giveaway.
I don't know the differences between red & blue kits (with the exception of the neoprene rear main for early reds) as I've only played with blue & black Holden V8s. One could suggest the intake gaskets again could be the way to pick them, as the EGR port shape changed, but the last ones I used (3 years back) were a multi-fit style.
