#1 Posted : Tuesday, 24 September 2013 3:36:40 AM(UTC)
I have a 4bbl Holden manifold but I can`t remember what model it`s from apart from a red v8, the number is 9945688 88-2 any help would be good thanks
HK1837 Online
#2 Posted : Tuesday, 24 September 2013 4:17:08 AM(UTC)
It it exhaust heated or water heated? U shaped EGR port?
#3 Posted : Tuesday, 24 September 2013 6:27:29 AM(UTC)
I will check tommorow , it does however have a hole about 5mm drilled in L and R side of the manifold just below where the carby mounts to , this is not on other manifolds that I have ?
#4 Posted : Tuesday, 24 September 2013 6:30:23 AM(UTC)
I don't have that casting number recorded but it is 'era correct' for an HZ/VB ADR27A 5 litre.
As per HK1837's request it probably has a U-shaped EGR centre port & no water heating.
The extra drilled holes are probably for aftermarket water injection or upper cylinder lube for an LPG engine.
#5 Posted : Tuesday, 24 September 2013 6:47:26 AM(UTC)
Thanks Dr Terry
