Diff noise. What is the best way to attend to this. Presume this is a Salisbury 3.08 . Are banjo gears interchangeable.
No banjo does not go unless it's the small salisbury but they first came in the WB. Go see a diff shop and ask what's best for you. Or put up with the wine until she blows.
Small Salisbury was first seen in UC Torana & then TD Gemini in early 1978 & then in VB Commodore in late 1978, preceding wB by around 2 years. Dr Terry |
That's right but i was on about his HX type sedan. Yep That shure is a big strong diff for the gemini. Remember the diff in the 4 cyl HB, got one of them in the bush hear, now thats the smallest salisbury i have ever seen Haha.
