What does the Insert number refer to in the HR ID plate
1242 122
Thanks: 1 times Was thanked: 615 time(s) in 582 post(s)
From the info I have at the moment:
1242 hs been found on a 235A with 186S and front discs. 122 has been found on both 225A and 235A with 186 and front discs.
Info is far from complete though but given the way codes seem to be indpendent of model codes it woul be a good bet there will be more models out there with teh same codes. |
