Just wondering what size rims and back space you lads are running.i don't want to roll guards nor tub nor shorten diff.i realise that makes choice limited but body is smick.it has king lows on front. It's a monaro not sedan.looking at convo pros.thanks heaps.
Thanks: 6 times Was thanked: 2 time(s) in 1 post(s)
15x60x215 15x60x195 front lowered hk monaro,
I'm sourcing 15x6 Pontiac Rally rims for my HK GTS, standard ride height. I'll run whatever V rated tyres I can find, probably 215/60/15. |
buick rally wheels 15x7 I rally like them ,was gunna get cragers but prefer these and everyone has bloody cragers
I'm just using the 15x6 version of the HQ rally rim, primarily as I want V rated tyres as almost all 14" tyres are only H rated which is lower than the original fitment to a HK GTS327 |
What is the backspace on the Rallye rims above? |
I am thinking of getting new wire spoke wheels for my old 1985 Jaguar Daimler XJ12 series 3, but how do you keep them from rusting up. I think they will look the best for this type of car and I don't like all the new types of modern day wheels at all, who wants wheels that look like hub caps and the first time you even touch a gutter they are rooted.
The guards have the inside lip removed and my diff is vr commodore I couldn't go any wider in tyre size but the way it's set up now is perfect.
I'd say they must be 4" backspace if you needed to remove the guard lips.
We've spent many hours and 1000's of $ putting the guard lips back to standard, and I won't be lowering the cars at all. I measured the XW GT 9" I have and from flange to flange it is the same width as a HK banjo. |
this is an ex race car and I have been building it up to a nice street car but will never be concourse .its got vp front discs and 4 pot hilux calipers big roll bar nalathane ect handles and stops better than most modern cars
I have a red GTS327 similar, been a drag car and had guard lips all cut up. |
4 inch
Cool, hopefully 4.5" backspace fit without scrubbing. I have to run proper 15" rims to clear the front brakes. |
if you arnt going as low as me you should be ok,il be interested to see the results
