Oldolden Offline
#1 Posted : Friday, 24 July 2015 9:26:13 PM(UTC)
Oldolden
Do all red 6 cylinder engine use the same harmonic balancer?
Mines developed a leak, I think from memory the seal collapses and wears a groove in the balancer?
looking at having a replacement when I get around to the job if needed,
Although the engine has only 43000 miles from new, may only need a new seal.
#2 Posted : Friday, 24 July 2015 10:40:23 PM(UTC)
Yes, all Red Holden 6s use the same balancer & so do early Blue 173s. The later engines have a differently located timing tag & the Blue/Black 202s use a heavier balancer.
If your still unsure, after fitting, just check TDC by inserting something down the spark plug hole to check the piston position against the timing mark itself.
