You have been a member since:: 16/06/2011(UTC) Posts: 65
Hey guys I've moved several times whilst working on my.kingswood and the bits that mount the cross member Tk chassis have gone walkabout. The bolts and plates. Are replacement kits available somewhere? Also the linkages that go with the box too. Thanks in advance.
Joined: 16/04/2014(UTC) Posts: 768  Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
The crossmember nut plates are a fairly agricultural lump of black steel with two 3/8" UNC threaded holes at the same centres as the crossmember mounting holes. They are 1-1/4"W x 4-3/8"L x 5/16" thick with the tapped holes at 3-3/8" centres. Very easy to make or have made. The bolts are 1" x 3/8"UNC SAE grade 5. I have seen the nut plates on EBay, but I'd try a wreckers first as they look expensive to me for what they are. Can't help with the auto linkage. Edited by user Monday, 2 November 2015 4:21:44 PM(UTC)
| Reason: Not specified
Cheers brother I'll look into that!
