Does anyone know how to disconnect the theft deterrent system on a VP V6? I am using the engine and wiring harness in another project and I want to remove all unnecessary circuits from the harness. I have the wiring diagram manual and everything else seems easy enough except the theft system. I don't have the other manual that explains how it works so I am not sure what to do.
thanks Brian
Hi Brian.
The theft deterent system in a VP is much simpler than the VR onwards type.
The switch in the LH front door pillar switches it on & off.
The trick is, if you understand wiring, this switch controls 2 separate circuits & opens 1 while cl |
Thanks Terry, it is an executive sedan and the manual is volume 8 Wiring Diagrams VP&VQ series 11 number M40320H.
At the moment the entire harness is out of the car and spread out all over the floor. I have identified and tagged all connectors and t
