Hi all, Been a while since I have been here, but after the latest drama from the slave and master I have decided to change from a 5spd conversion to trimatic in my HR PV. After hunting around on the net I am still stumped on the crossmember needed and also any other things needed. ( not being too savvy with the www) I know tailshaft would be different. Question I have is, would the crossmember from my Castlemain conversion be OK for a trimatic or would I need to source a specific member ? Cheers, Steve.
Thanks: 1 times Was thanked: 615 time(s) in 582 post(s)
HD-HK 6cyl Powerglide crossmember and tailshaft will work. HK all synchro 3spd crossmember and tailshaft as well. |
