Joined: 7/09/2016(UTC) Posts: 163  ![Australia Australia]() Location: Blackbutt Queensland Thanks: 9 times Was thanked: 4 time(s) in 4 post(s)
I removed the rubber floor mat from my ute and there is surface rust on the floor. It appears that it was painted with a red oxide primer originally. Is this still available or what should I use instead. I am not a panel beaters or painters backside..... so go easy on me? The windscreen was replaced and a round top screen rubber was fitted instead of a square top rubber so it will be coming out again. I didn't notice at the time until my mate from NZ was using the car soon after the screen was replaced and he got soaked when it rained heavily. Thanks |
48 215 |
Thanks: 1 times Was thanked: 615 time(s) in 582 post(s)
I don't think you can buy the red lead paint as it was but you can buy a substitute. Unless you want the original look just buy a modern primer/etch and spray over it. |
Thanks: 1 times Was thanked: 22 time(s) in 21 post(s)
Red killrust must be close? But you won't see it anyway as HK said.
Thank you for your replies. I will look into the killrust. Cheers Ron |
48 215 |
As I said you can buy a substitute that looks the same but it isn't red lead. I don't know if it is an acrylic anymore either so make sure you don't try to spray acrylic over it. |
