I picked up a cheap set of reco blue heads to replace the worn out reds on my 308. Can I just bolt them on using the red manifolds?. Will it overhead if the blue heads heat passage is blocked?.
Thanks: 1 times Was thanked: 635 time(s) in 597 post(s)
They bolt straight on, but you will need to get a 253 or 308 blue/black valley cover or a KC castings 253308 manifold. The KC one is designed to fit all of the pre VL Walkinshaw heads.
The problem you will come up against is that it sounds like you hav |
Thanks for that Byron. I have a HT pre-pollution 308. The plan was to use the pollution heads and the pre-pollution manifold. I guess that's a no go then.
