Joined: 25/02/2023(UTC) Posts: 3 ![Australia Australia]() Location: perth
Guys, the clutch return on my HK does not return it to the top position. I have replaced the pressure plate, recond the "rat trap" and all related springs, shift levers and clutch rod. I depress the clutch and it will not return to top position. Can anyone help. Cheers Lindsay. Frustrated HK owner.
Thanks: 3 times Was thanked: 45 time(s) in 44 post(s)
You should only be just able to move the rod on the clutch fork by 1/8 of an inch or so by hand pressure, any more than that could account for the pedal not coming up
Joined: 11/09/2016(UTC) Posts: 233 ![Australia Australia]() Location: OZ Was thanked: 29 time(s) in 27 post(s)
Sounds like the clutch pedal over centre spring and yokes may be missing or damaged.
Guys, adjustment recommendation was spot on. Thanks. All good now.
