JasonCrowe Offline
#1 Posted : Tuesday, 23 April 2024 4:30:19 PM(UTC)
JasonCrowe
Hi All,
I'm new to this forum and have had a look around for an answer to my issue but can't see anything. I've had an interim issue where occasionally had the float bowl run dry and so the engine stops. Worked my way up and replaced the fuel pump, fuel filter, and float needle. Had a bit more of a play today and with the top of the carby off it runs fine, idles, etc. However, when I screw the top down, the float bowl runs dry. The gasket between the two is pretty ordinary and I've ordered a replacement but I was wondering what else it could be. Cheers Jason
