Lokk at this:- https://www.ebay.com.au/itm/276578760080Is this a good project, or what ? Dr Terry |
I've seem heap better for sale but not that cheap. WOuld clean up OK, I reckon fix rust ald leave it how it looks, but put an injected 5.0L or similar eg a 454 or 350 or whatever takes your fancy. Even a 308 and Trimatic.
I can confirm that:
Disc brakes are not original. This car had drums. Engine is not original, original was a QE low comp engine. Power steering is not original. |
Originally Posted by: HK1837  I can confirm that:
Disc brakes are not original. This car had drums. Engine is not original, original was a QE low comp engine. Power steering is not original. Something odd about that floor shift hole too. Maybe it was originally a 3-sp column shifter manual. Dr Terry |
It was an M15 3spd originally. Only mechanical option was the low compression 173. |
