buxomyoungwench Offline
#1 Posted : Sunday, 26 June 2005 10:14:11 PM(UTC)
buxomyoungwench
Hi guys
A couple of years ago someone replaced my fuel pump to get me out of a bit of trouble. Now she's coughing and farting every time I start her up (and smells a bit petrolly when driving along).... Should I have gotten the carby adjusted or something after the pump was replaced? Nearly forgot.... "She" is hq with a red 202 and extractors.
(not sure if the extrators would make a difference)....
#2 Posted : Monday, 27 June 2005 9:10:41 AM(UTC)
Could be a sticking choke, or a leaky carb. Have a look at the base of the carb with the engine running if it looks damp around there most likely it just need a new float needle or possibly a new float if the old one is punctured.
Also when the engine is
#3 Posted : Saturday, 8 October 2005 8:34:37 PM(UTC)
buxomyoungwench
Was a brand new pump
#4 Posted : Sunday, 9 October 2005 9:01:37 AM(UTC)
Long time thinking about that!
Quite likely the needle and valve need replacing, easy job and not too expensive. That is if there is fuel around the carby.Did you check around the carby as I suggested?
#5 Posted: : Wednesday, 12 October 2005 5:12:12 AM(UTC)
also fuel lines or gasket leaks
VN Calais, V8 Auto, Blown etc etc.
Air con, Electrical, Car audio Master.
#6 Posted : Wednesday, 12 October 2005 5:12:46 AM(UTC)
vacuum leak ^^^ in regards to gaskets
#7 Posted : Sunday, 16 October 2005 9:35:00 PM(UTC)
did you check the float level in the carb. if not adjusted correctly this can cause the symptoms you describe
#8 Posted : Tuesday, 18 October 2005 3:31:10 AM(UTC)
check the throttle lever it leaket in my hz and the same thing happened
"horsepower is how fast you go into the wall torque is how much of the wall you take with you"
#9 Posted : Wednesday, 19 October 2005 6:22:27 AM(UTC)
check ya points champ,small gap and burnt points can also cause 'coughing & farting'.
