Joined: 17/06/2020(UTC) Posts: 3 ![Australia Australia]()
Can somebody please give me the exact measurement of the input shaft bearing retainer, from the rear face of the base to the end of the tube? Thanks.
Joined: 6/07/2019(UTC) Posts: 474 ![Australia Australia]() Location: bayside Melbourne Thanks: 303 times Was thanked: 40 time(s) in 39 post(s)
Originally Posted by: dlm  Can somebody please give me the exact measurement of the input shaft bearing retainer, from the rear face of the base to the end of the tube? Thanks. from the flat flange part that bolts to the gearbox case at the front to the tube end? There are 2 different types (based around the front seal) but I think they are the same length have several in the shed will measure this in the morning  |
Originally Posted by: dlm  Can somebody please give me the exact measurement of the input shaft bearing retainer, from the rear face of the base to the end of the tube? Thanks. my steel rule says 124.5mm on one of the V8 M20s I measured and just on 125mm on the other M20 (and one of the M21s I have) HTH |
