#1 Posted : Friday, 22 July 2005 6:39:00 AM(UTC)
You are a member of these groups:: Guests
hey all i want to fit a 308 in my commy (which has a 253 in it now) with a trimatic now my question is the 308 i have is a turbo pattern so do i have to get a turbo to trimatic bellhousing or is there another way
#2 Posted : Friday, 22 July 2005 6:51:42 AM(UTC)
Take advantage of the turbo pattern & fit a TH700R4(aka 4L60) from a VN or VP, and get the economy & cruising advantage of a 4 speed auto with overdrive.
#3 Posted : Friday, 22 July 2005 6:53:49 AM(UTC)
no i dont want to piss art around just want to change the motor over thats it
Dylan Offline
#4 Posted : Friday, 22 July 2005 7:41:22 AM(UTC)
Dylan
you will need a new bellhousings, i have never needed one but this mob sells them http://www.torque-power.com.au/ and CRS and Dellow probably do aswell, but dont quote me on that.
#5 Posted : Friday, 22 July 2005 7:44:13 AM(UTC)
OK, well the trimatic only ever came with a tri-pattern bellhousing, not a turbo/chev pattern, so unless you can find an aftermarket supplier of bellhousings <edit - see the post Dylan just made directly above> to allow a tri to bolt to a turbo, you
Edited by user Friday, 22 July 2005 7:45:54 AM(UTC)  | Reason: Not specified
#6 Posted : Friday, 22 July 2005 8:07:38 AM(UTC)
Hi Guys.
I don't know if it would be an easier or cheaper option, but GM in South Africa used Tri-Matics behind Chev 4 & 6 cylinders. These have the standard Chev bolt pattern & would be cheap as, at wreckers in SA.
Dr Terry.
#7 Posted : Friday, 22 July 2005 6:43:10 PM(UTC)
Another easy option is to get a TH350. These were standard in some VB-VH Commodores. The box will fit in behind the 308, using the same tailshaft. You will also need (all standard Holden):
VB-VH TH350 shifter rod.
VB-VH TH350 speedo cable.
VB-VH TH35
#8 Posted : Saturday, 23 July 2005 8:47:18 AM(UTC)
or one from a statesman maybe?
#9 Posted : Sunday, 24 July 2005 4:40:42 AM(UTC)
An early WB Statesman or late HZ 308 auto one will also do, but the shift rod and speedo cable will be wrong. You will also need the Commodore gearbox x-member.
#10 Posted : Sunday, 24 July 2005 5:36:58 AM(UTC)
i've never done it but apparently you can remove the pin + swap the lower shifting arm to the other side, but that still won't help with the speedo...
#11 Posted : Sunday, 24 July 2005 7:02:53 PM(UTC)
You don't need to as Commodore trimatics shift on the left also. Only the TH350 rod is needed (it may be the same as trimatic but can't remember exactly).
#12 Posted : Sunday, 24 July 2005 7:49:35 PM(UTC)
DOH! i was thinking of trimatics where older ones have the shift linkage on the RHS + as you say commy trimatics have it on the left.... 8|
Sandman Offline
#13 Posted : Sunday, 7 August 2005 10:41:07 PM(UTC)
Sandman
You can get a adaptor plate to go from 308 pattern to chev pattern, Although I think getting an aftermarket bellhousing would be easier because to use an adaptor, you have to space out the convertor and cut the tailshaft, both by the thickness of the adap
#14 Posted : Sunday, 7 August 2005 11:50:03 PM(UTC)
i once used a CRS adapter they create more problems than they are worth, you can even get blocks redrilled quite easily these days.
Guest (9)
