#1 Posted : Saturday, 27 August 2005 9:36:48 PM(UTC)
Hi Guys,
As good complete second hand heater systems for hktg's seem to be non-existant and aftermarket setups cost $$$'s i'd like to know if i can use some of the heater/aircon parts from a VL in a HK? could i at least use things like the heater/blower and the a/c compressor?There's loads of room under the dash so i'm not too concerened with custom ducting/controls etc, unless it fills the footwells...hehe, but I would think the size of the VL parts wouldn't be a problem. Is there any hope in hell of running the vacuum controls? or would it be far easier to just setup a couple of switches in the dash and use the original ducting system (single open/close footwell control). Is it too hard to fit demister ducting to a non-optioned model and how would i control the floor/demister changeover? Does anyone (Qute?:) have any info or diagrams of the VL heater and air systems or know which publications would have good info?
any help much appreciated :)
wayne Offline
#2 Posted : Saturday, 27 August 2005 10:17:37 PM(UTC)
wayne
how mutch differance in hg to hq sister has a paddock full of hq's and she is selling them off so may be able to put you on to her lives out armidale way if theis helps post a contact no
First
On
Race
Day
#3 Posted : Sunday, 28 August 2005 2:43:28 AM(UTC)
Best publication is the factory VK or VL service manual (they use the same box & almost identical controls).
The prob with a VK/VL bos is it is a top-feed for the air, on the LH end of the plenum, and may need serious metal surgery to make it work.
#4 Posted : Sunday, 28 August 2005 5:31:06 PM(UTC)
Hi 70ute.
There's not as much room as you think under an HK/T/G dash.
I would continue looking & try & find a factory unit. You will have to recore the heater & fix up the cables etc. no matter what old unit you get.
Dr Terry.
#5 Posted : Sunday, 28 August 2005 7:22:06 PM(UTC)
thnaks guys...
This page was generated in 0.065 seconds.
