#1 Posted : Monday, 10 January 2005 1:18:11 AM(UTC)
I have a fresh 4.1 alloy head that has suddenly begun to run rough at idle and is sluggish on acceleration.
Placing figers accross the primary on the weber, almost blocking it(choking), settles the motor to correct idle, very smooth.
I have rebult the weber, twice, timing is correct, no obvious vacuum leaks.
Any thoughts??
#2 Posted : Monday, 10 January 2005 12:18:36 PM(UTC)
have u tuned the carby
#3 Posted : Monday, 10 January 2005 5:19:21 PM(UTC)
idle screw out 2.5 turns to begin with, adjustment made no difference to idle.
float set at 7mm
#4 Posted : Tuesday, 8 February 2005 10:59:20 AM(UTC)
Idle screw seat stripped, buy new idle screw it comes with a replacement interference fit metal seat which is easily pressed into recess, it is a common problem.
#5 Posted : Monday, 11 April 2005 6:59:44 AM(UTC)
Sounds like you might have a valve not seating properly.
#6 Posted : Monday, 11 April 2005 7:06:40 PM(UTC)
there is a power wire that goes to the carb for the idle,there are 2 wires 1 goes to the choke the other goes to the idle switch(its on the same side as your mix screw but just above it).first off check to see if its connected then start the car and let i
#7 Posted : Sunday, 29 May 2005 12:11:34 AM(UTC)
i've got almost exactly the same problem as 'confused'
rough at idle, stalls when the revs are dumped quickly (hard braking), using a tanker load of fuel.
mechanic #1 'cant find anything, mate!' (checked for leaks)
mechanic #2 'needs a tune up, m
#8 Posted : Sunday, 29 May 2005 1:29:48 AM(UTC)
vaccum hose from brake booster to manifold had a hole in it !
put a new one on........no change !! bugger
carlos
#9 Posted : Monday, 30 May 2005 12:45:04 AM(UTC)
please help.efi motor on gas will idle only
#10 Posted : Tuesday, 31 May 2005 7:50:51 AM(UTC)
solved..........second hand weber carby from the wreckers.......$60 bucks !!
runs sweet as a nut
carlos
#11 Posted : Wednesday, 1 June 2005 11:20:50 PM(UTC)
How long has the exhaust been on the car , somtimes the "cat.converter" blocks up and gives similar symptoms ( geesh I sound like a doctor)
C/F
#12 Posted: : Friday, 10 June 2005 2:39:04 AM(UTC)
This page was generated in 0.131 seconds.
