YetAnotherForum.NET Help
one tonner man Offline
#1 Posted : Monday, 26 September 2005 8:40:14 AM(UTC)
one tonner man
I only just installed the power steering set I had laying in the shed this weekend on to a HQ 6cl. Seems to be working find but I keep getting a grundging noise when turning the steering wheel. I checked the fluid and it is right to the top and primed the pump when I installed it. Just like to know is the grundging noise from the power box or from the pump. If the noise is coming from the pump can it be serviced as it looks like a sealed unit? If the power box needs to be services can anyone give me an idea of what the cost would be.
If I agreed with you we`d both be wrong.
classic oz wreck Offline
#2 Posted : Monday, 26 September 2005 8:58:56 AM(UTC)
classic oz wreck
thr boxes dont generally make noises..just get notchy or leak..pumps make those noises either on full lock or under load if there sad...
www.classicozwreck.com.au
Taz2 Offline
#3 Posted : Monday, 26 September 2005 4:13:10 PM(UTC)
Taz2
Sounds like you may still have air in the system.
Jack the car up until the front wheels are clear of the ground, and the vehicle is stable.
Start the engine, then turn the steering whel from lock to lock a few times to rid the system of any air.
In thrust we trust
#4 Posted : Monday, 26 September 2005 10:56:18 PM(UTC)
I agree with Taz2. Especially if there is ANY notchiness in the steering when turning tightly at slow speed.
The manuals recommend 3 to 5 turns lock-to-lock (but only just touching full lock either side) to bleed the power steering system.
The power
#5 Posted : Tuesday, 27 September 2005 1:07:09 PM(UTC)
one tonner man
Thanx for the info guys... I try jackking her up tonight after work. If that das not fix it I put in one of the spar pumps I got on this weekend and see if it still gives the same noise.
