treborsenrab Offline
#1 Posted : Saturday, 15 October 2005 4:08:04 AM(UTC)
treborsenrab
186 motor,currently in a hk-but i know its not the original,
eng no-186p470386
also stamping on head-7437395,hope someone can decipher this.
gunna have a look back through the forums now to find the stories of what the "L" and the "H" circled on the Lhs rear of head stands for.
Thanks Guys
Rob
be an innovator, not a imitator
#2 Posted : Saturday, 15 October 2005 6:56:21 AM(UTC)
Hi trebor.
The 186A prefix is for an HR 186 engine, although the 470386 serial number seems a bit high.
The H & L casting on the head is an interesting one, because the 161 hi-comp & 186 hi-comp use different heads one has L & the other has H, so th
#3 Posted : Saturday, 15 October 2005 8:47:00 PM(UTC)
186P is correct for HK
#4 Posted : Saturday, 15 October 2005 9:18:06 PM(UTC)
treborsenrab
Interesting Guys. Back b4 i could get a licence, i brought a HD special,had the same starting prefix on donk{can still remember it-186p111265!},must have been a 186 out of a HK than? Dr Terry,u confused me with your reference to "186A".was that a typo?And
peterwmh Offline
#5 Posted : Sunday, 16 October 2005 12:05:34 AM(UTC)
peterwmh
H and L are high and low compression respectively. If you have both versions havea look at the shape of the combustion chambers, the H is a smaller kidney shaped chamber than the L one. Well that's how they look on mine anyway!!
Peter
Never late wi
#6 Posted : Sunday, 16 October 2005 1:20:37 AM(UTC)
treborsenrab
Hi Peter,cheers for your reply. have two heads here with same size shape combustion chambers, both have H stamped on them.mate over road with a HP{179} had head off it,small chambers with L stamped on it.
Confusing and makes for an interesting topic.
Th
#7 Posted : Sunday, 16 October 2005 1:45:23 AM(UTC)
looks like a typo, but as dr terry also says the H & L casting refers to heads from different capacity motors rather than the comp. ratio. AFAIK different piston height was a major determining factor of compression.
[IMG]http://i11.photobucket.com/albu
#8 Posted : Sunday, 16 October 2005 3:45:46 AM(UTC)
Was thanked: 603 time(s) in 570 post(s)
I might be wrong, but I thought the H and L did stand for HIGH and LOW respectively, but only applied to engines that used the large and small combustion chambers to achieve low and high compression versions of the same engine eg the 161 and 173. That is
#9 Posted : Sunday, 16 October 2005 6:39:46 PM(UTC)
Hi Guys.
The 186A bit was more of a mis-read than a typo, I must have been half asleep.
Any way as the others have pointed out, the 186P470386 is an HK/T/G 186 but with the 470386 serial number makes it a very late HG. Also the 7437395 head will hav
#10 Posted : Sunday, 16 October 2005 8:37:01 PM(UTC)
The High and low compression from Byron works for me also. The heaa that you have listed is used for both 186 high compression and 161 low compression.
I like the theory about the engineers name, I have "suggested" that they might be someones initials
#11 Posted : Sunday, 16 October 2005 10:12:45 PM(UTC)
treborsenrab
Thanks for the replies, Anyone got any access to staff names from back in the 60's? may have been an engineer\designer with those initials,long shot i know,and probably a security issue also.But man,id love to find out,as many of you also would!Anyway,im
#12 Posted : Sunday, 16 October 2005 10:55:19 PM(UTC)
treborsenrab
By the way-were the 308hp and the 179hp released at roughly the same time?
Rob
#13 Posted : Sunday, 16 October 2005 11:52:33 PM(UTC)
treborsenrab
forget that question,that would have been with the release of the HT around 1969 the 08 was released.trying to tie in the hp179 and hp 308 stampings-makes less sense now!!
#14 Posted : Sunday, 16 October 2005 11:53:44 PM(UTC)
#15 Posted : Monday, 17 October 2005 6:31:13 AM(UTC)
treborsenrab
Byron,most feasible answer ive heard yet.maybe there was some hp308's that remained as that. maybe we will never know."the truth is out there"!
Rob
This page was generated in 0.104 seconds.
