#1 Posted : Friday, 11 November 2005 1:37:46 AM(UTC)
Hi all,
Seems my electric aerial on my VP commodore broke half way up through the chrome tubing. I've obatined a replacement consisting of tubing and the extending 'rope' with teeth for the motor to drive.
Next question is how do you get to the aerial to replace the mast, do I prise off the black plastic guard surround and hope for a small nut or do you take a wheel off and start removing inside guards?
cheers,
Ben
#2 Posted : Saturday, 12 November 2005 3:29:12 AM(UTC)
Hi Ben.
You have to remove the aerial assembly from the car, in other words undo & pull back the inner LH guard & also remove the inner trim panel & computer from inside the car to gain access to the mounting bolt. No need to touch the black plastic su
#3 Posted : Tuesday, 15 November 2005 12:42:39 AM(UTC)
Thanks Terry,
Got it out and panels removed etc but now don't have any power to retract it again. wires are as before and properly earthed but nothing. There is a small relay clicking noise when I press up or down but without a second person around I can
#4 Posted : Tuesday, 15 November 2005 7:55:28 AM(UTC)
Hi again Ben.
It sounds like you're just about there, but you will find is easier to disconnect it totally from the car & do the repair on the bench using a another battery or a power pack or similar.
The problem you current have is no earth, the mo
#5 Posted : Tuesday, 15 November 2005 8:07:54 AM(UTC)
Thanks again Dr,
I tried to have it earthed with some aligator clips on wire but possibly didn't get a great earth, not enough hands as usual. Will try again when someone is around to press the switch so I can play with wiring and see what happens!
chee
