bstardchild Offline
#1 Posted : Friday, 2 December 2005 8:01:58 PM(UTC)
bstardchild
Hi people
I'm on the other side of the world to you guys but I run similar cars and I'm after a bit of help - I'm not sure if I can link to pictures on here but I'll have a go
Heres my track day tool - 3.0i 12V 180 Bhp 20 yrs old with 200,000 miles under it's belt - I'm only the second owner and still does 140 if you plant the load pedal 8) I'm converting it to a GM 24V six at the moment
It had one of these in it
This is what is going in it
Heres the previous project - Senator 3.0 24V Auto - Dead engine from a snapped timing chain - currently being rebuilt too - slowly!!!
My questions are simple to start with - what are the Holden model equivilents?
Edited by user Friday, 2 December 2005 8:06:45 PM(UTC)  | Reason: Not specified
Mr Void Offline
#2 Posted : Friday, 2 December 2005 8:59:08 PM(UTC)
Mr Void
G'day mate - welcome to Australia!!
I am guessing (don't worry someone will correct me if wrong) that our RB30 engines (out of the VL commodores) are similar. They were also avaiable as RB20 and RB25turbo - obviously the 30, 20 & 25 stands for 3.0L, 2.0L
___________________
peter_flane Offline
#3 Posted : Friday, 2 December 2005 9:14:13 PM(UTC)
peter_flane
When you say it does 140 when you plant the pedal I assume that is Miles Per Hour?
bstardchild Offline
#4 Posted : Saturday, 3 December 2005 4:32:03 AM(UTC)
bstardchild
bstardchild Offline
#5 Posted : Saturday, 3 December 2005 4:32:54 AM(UTC)
bstardchild
GMH1975 Offline
#6 Posted : Saturday, 3 December 2005 4:53:57 PM(UTC)
GMH1975
Hi bstardchild.
I would say that the first car is a cross between a holden VK-VL and the second car is positively the same as the holden VN to VP series commodore.
Would probrbly be a good idea to measure the bushes you want replaced and send that info
Not the BLOODY Kingswood
#7 Posted : Saturday, 3 December 2005 5:16:26 PM(UTC)
The coupe looks like a chevy monza and the sedan VN-VP for sure
bstardchild Offline
#8 Posted : Saturday, 3 December 2005 5:55:25 PM(UTC)
bstardchild
Originally posted by GMH1975
Hi bstardchild.
bstardchild Offline
#9 Posted : Saturday, 3 December 2005 5:58:59 PM(UTC)
bstardchild
bstardchild Offline
#10 Posted : Saturday, 3 December 2005 6:01:19 PM(UTC)
bstardchild
On teh Senator this is the problem Bush?
[img]http
#11 Posted : Sunday, 4 December 2005 12:41:04 AM(UTC)
the bush u refer 2 looks like a vp 2 vs commodore irs
#12 Posted : Sunday, 4 December 2005 9:55:41 AM(UTC)
That's exactly what it is, and you can get that bush in Oz quite easily from most suspension places.
It is the bush that mounts the IRS cradle to the bodyshell, and is fitted from VQ (VP) right thru to current models with IRS.
I would hazard a guess
#13 Posted : Sunday, 4 December 2005 5:50:35 PM(UTC)
Hi bstardchild
Without going into too much history, the first series of Commodores in Australia was built by using a Senator A nose onto a Rekord C body. This was done back in 1978 & the reason for the longer nose was, while we used the German body, al
#14 Posted : Sunday, 4 December 2005 8:56:21 PM(UTC)
click the link to the rare spares online shop and send them an email, they should be able to help with measurements and they also export worldwide.
bstardchild Offline
#15 Posted : Monday, 5 December 2005 6:13:53 AM(UTC)
bstardchild
Originally posted by Dr Terry
Hi bstardchild
#16 Posted : Monday, 5 December 2005 10:22:14 AM(UTC)
One thing overlooked is that the Opel base was not structurally strong enough for Australian conditions and was significantly modified after they developed a habit of breaking in half. Also probably due to the Aussie engines. The engines you show in your
bstardchild Offline
#17 Posted : Monday, 12 December 2005 7:34:46 AM(UTC)
bstardchild
#18 Posted : Monday, 12 December 2005 7:48:42 AM(UTC)
The australian VN-VS series that ran from 1988 to 1997 (and into 2000 in some variants) looks to be the most similar in design to those "cracked" pics you have posted.
Our sedans have a much more substantial rear bulkhead behind the rear seats than the
bstardchild Offline
#19 Posted : Monday, 12 December 2005 7:49:19 AM(UTC)
bstardchild
Footnote to the above post - the guy above was very unfortunate - he was restoring his Lotus Carlton and had the engine & gearbox fully rebuilt at a engineering workshop - there was a fire (electrical fault in the building) and the whole paise was burnt t
bstardchild Offline
#20 Posted : Monday, 12 December 2005 7:56:24 AM(UTC)
bstardchild
Edited by user Monday, 12 December 2005 7:57:12 AM(UTC)  | Reason: Not specified
This page was generated in 0.122 seconds.
